A/C on it starts to shake and it drives really rough and eventually overheats
21,346 MILES • V6 • 4WD • AUTOMATIC
KMCCOVEY
When I turn my A/C on it starts to shake and it drives really rough and then sometimes the water from the reservoir will over flow and boil and spits most of the water out then eventually my car will overheat.
Aug 3, 2020 at 4:46 AM
Good afternoon,
When was the last time the thermostat was changed?
Does the system leak coolant without the A/C?
https://www.2carpros.com/articles/engine-overheating-or-running-hot
https://www.2carpros.com/articles/radiator-pressure-test
I am concerned about running rough. You have misfires going on for some reason and when you add the load of the A/C, it overheats. That tells me you may have a failing or failed head gasket.
If the car overheats, the A/C system will not work correctly as the hot engine will not allow cold air.
Aug 3, 2020 at 6:24 AM
