Test the wire going to the compressor and let me know.
May 23, 2023 at 4:29 AM
YAZIDAN
MEMBER
When the system is on and the compressor is Not working there is power 12v I used a test light to check.
May 23, 2023 at 5:42 AM
✓Experienced Mechanic
Okay, you have found the problem; the compressor coil is bad and needs to be replaced. You may need to remove the compressor which at this time you may consider replacing it as a whole unit. Here is how the job is done step by step and I have included instructions in the images below for your car.
