A/C not cooling
219,000 MILES • 4.4L • V8 • 2WD
KDUB280
Hello. At the begin of summer I parked my car due to some costly repair, the A/C worked fine before. Now after summer nothing. It is still fully charged but not getting cold.
Nov 24, 2020 at 1:49 PM
We need to start with finding the pressures of the high and low side. Then we need to see if the compressor is engaging when you turn the A/C on. If it is not we can go from there but again, we are going to need the pressures just to make sure they are correct. If they are too low the compressor will not come on. Plus unless we are checking the pressures it may seem like the system is still full when it is actually low.
Let us know what this info is and we can go from there. Thanks
Nov 25, 2020 at 12:32 AM
