Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Saturn
L200
Climate Control
Air Conditioner
Not Working
A/C compressor not engaging
2003 SATURN L200
82,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
PITTSRICO
MEMBER
1 POST
New compressor installed but still will not engage.
Jun 24, 2020 at 9:32 PM
Experienced Mechanic
Good morning,
I attached a wiring diagram of the system for you to view.
Do you have a test light to do some checks as to why the compressor will not turn on? there are 2 fuses I circled that need to be checked to be sure there is a voltage at the fuse.
Can you give me the Freon pressures of the high and low sides?
Images (Click to enlarge)
Jun 24, 2020 at 10:32 PM
Add image or video
Ask a new question
Engine won't start
Engine has low power
