So I replaced my whole A/C system and converted it to r134 how much pag oil do I add and how many pounds of Freon?
Apr 10, 2017 at 3:45 PM
HMAC300
✓Experienced Mechanic
if you replaced the system what parts were replaced? Did the new parts have oil in them a lot of times they do?
Apr 10, 2017 at 11:12 PM
PALAFOX23
MEMBER
I replaced the compressor, accumulator, evaporator, and the condenser and none of the parts had oil.
Apr 11, 2017 at 12:13 AM
HMAC300
put about seven ounces total in system it is best to add through compressor then turn over by hand of course this is assuming you still have the R-4 compressor that comes from the factory otherwise it may be different. if you replaced the lines as well then add another ounce. then add some Freon and cycle compressor a few times, discharge and then evacuate ofr about fifteen minutes before recharging again.
