air half as cold as desired but better than warm, short intervals between cycling on and off, will have brief but audible belt screech about one out of every ten cycles. tension-er pulley bearing replaced radically reduced screech. no gauge readings taken. is it possible there is another cause other than bad internal compressor bearings? thank you for your expertise.
Apr 19, 2018 at 5:45 AM
