A/C blows cold air for around 10 minutes and then just blows hot air the rest of the time driving
139,000 MILES • 4 CYL • 2WD • AUTOMATIC
BREESEMTP
  • 10 POSTS
I had a leak fixed in it and recharged. I also changed out the relay and fuses. It also blows out a musty smell through vents right as the warm airs starts to blow. Any suggestions on what could be the cause of this?
May 2, 2020 at 7:02 AM
  • 110,248 POSTS
When it starts blowing warm, have you noticed if the A/C compressor is still cycling on and off? If you turn it off and then right back on, does it work?
I'm questioning if the evaporator is freezing up or even there were issues with the low side pressure line can freeze up if the Freon is low. I realize you had it done recently, but anything is possible. As far as the evaporator freezing up, often times it is a result of the control module keeping the compressor engaged continuously. If nothing is freezing up, then we will have to check air door actuators. Something could be closing off the evaporator from the inside of the vehicle.
Let me know. Also, let me know if this has automatic climate control or not, if you hear the compressor cycling when there is no cold air, and pay attention to see if the compressor is cycling and not staying engaged all the time.
May 2, 2020 at 11:45 AM
BREESEMTP
  • 10 POSTS
No, i haven't check the compressor once it starts to do that. I'll look at that tomorrow and get back to you.
May 2, 2020 at 11:48 AM
  • 110,248 POSTS
Sounds like a plan. Also, when it is working, see if you notice it cycling on and off. It should, otherwise it will freeze up.
May 2, 2020 at 2:44 PM
BREESEMTP
  • 10 POSTS
I just ran the car out in the yard until the air stopped blowing cold and checked under the hood and the compressor was turning on and off while the air was cold, then when it started to blow warm air the compressor is not spinning anymore when the air is on. What needs to be replaced? Just the clutch?
May 2, 2020 at 11:12 PM
  • 110,248 POSTS
The only way to confirm if it is the clutch is by checking if it is getting power. If it is and not engaging, then yes, the clutch.
Are you able to confirm that?
May 3, 2020 at 1:23 PM
BREESEMTP
  • 10 POSTS
It starts out running and then just stops after about 10 minutes.
May 3, 2020 at 1:24 PM
  • 110,248 POSTS
Keep in mind, there are other things that can cause it to turn off. A faulty pressure switch, temp sensors, and so on. That is why I suggested check if there is power. If there is, the clutch is the likely cause. If there is no power, then we need to dig in further.
May 3, 2020 at 1:32 PM
BREESEMTP
  • 10 POSTS
10-4. I'll check into that.
May 3, 2020 at 1:35 PM
  • 110,248 POSTS
Sounds good. I hope that makes sense. I never know if my directions are clear. LOL Take care and let me know.
May 4, 2020 at 1:22 PM
BREESEMTP
  • 10 POSTS
I wasn't able to check the power because i started back at work. I am taking it to my shop that i had original work done to fix the Freon leak. I am passing on all of our conversation.
May 4, 2020 at 1:24 PM
  • 110,248 POSTS
Not a problem. If you have a chance, let me know what is found. I'm sure it will help someone in the future having the same problem.
May 4, 2020 at 1:40 PM
BREESEMTP
  • 10 POSTS
Will do.
May 4, 2020 at 1:41 PM
BREESEMTP
  • 10 POSTS
Said it was a bad coil in the compressor. Putting new compressor in.
May 5, 2020 at 1:58 AM
  • 110,248 POSTS
Thanks for letting me know. Also, I'm glad it's going to be repaired and working. Let us know if you have questions in the future.
May 5, 2020 at 2:09 PM
BREESEMTP
  • 10 POSTS
Thank you for your help. I pick it up in the morning. I sure hope it works.
May 5, 2020 at 2:12 PM
  • 110,248 POSTS
You are very welcome. I'm sure it will work. If it doesn't let me know.
Take good care of yourself,
May 5, 2020 at 2:15 PM
