A/C sprays refrigerant all over my lower hose
108,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
ZHILL93
  • 20 POSTS
Every time I charge my A/C, high pressure steam starts spraying from the radiator area at the bottom. It sprays Freon all over my lower heater hose. I wonder why?
Apr 8, 2022 at 1:37 PM
  • 110,248 POSTS
That is approximately where the condenser is located. Either the condenser is bad or the lines to or from it are bad.
The condenser sits in front of the radiator. It actually looks like another radiator. There are two lines that attach to it, a compressor discharge hose (6) and liquid line (3) in pic 2 below. If I had to guess, I would think the discharge hose is the one leaking. There is an o-ring where it connects.
The easiest thing to do would be to get a freon with a dye in it so you can trace where the leak starts.
Let me know what I can do to help.
See pics below. Pic 1 is the condenser and pic 2 shows the connections.
Apr 8, 2022 at 2:23 PM
ZHILL93
  • 20 POSTS
It’s shooting out directly from the bottom and spraying the lower heater hose.
Apr 8, 2022 at 3:17 PM
  • 110,248 POSTS
Is it possible for you to take a picture of where you see it coming from? I ask because you mentioned the lower part of the radiator and the heater hoses are not down there. They run between the cylinder head and firewall. Do you mean the lower radiator hose?
Apr 9, 2022 at 12:59 PM
ZHILL93
  • 20 POSTS
Yeah, I mean the lower radiator hose and I will take a picture tomorrow. I got some UV dye refrigerant from Walmart today.
Apr 9, 2022 at 3:17 PM
  • 110,248 POSTS
I would install the dye and see what happens. If it is on the lower rad hose, it's likely one of the hoses.
Apr 9, 2022 at 4:03 PM
ZHILL93
  • 20 POSTS
It’s leaking and pouring on that hose.
Apr 10, 2022 at 5:30 AM
ZHILL93
  • 20 POSTS
Steam or something keeps coming out from there.
Apr 10, 2022 at 5:34 AM
ZHILL93
  • 20 POSTS
It’s spraying from the radiator direction and hitting that hose.
Apr 10, 2022 at 6:43 AM
ZHILL93
  • 20 POSTS
Here’s some more pictures.
Apr 10, 2022 at 10:17 AM
ZHILL93
  • 20 POSTS
These pictures at a little better.
Apr 10, 2022 at 10:46 AM
  • 110,248 POSTS
I looked through all pics. I am seeing wet areas facing the cooling fan shroud, the hoses, and everywhere. Since it is hitting the side of the fan shroud that faces the engine, check the original hoses I suggested. This is a large leak. You should be able to see on a hose if there is damage.
If the hoses or the connections are not suspect, then we need to pull the radiator back and see if it is coming from the condenser.
Apr 10, 2022 at 12:47 PM
ZHILL93
  • 20 POSTS
The hoses are fine I’ve checked them.
Apr 10, 2022 at 1:21 PM
  • 110,248 POSTS
Chances are it is the condenser itself. Disconnect the battery, remove the cooling fans, loosen the radiator, and move it back far enough to get a good look at the condenser. See if there is evidence of it coming from it.
Apr 10, 2022 at 1:36 PM
ZHILL93
  • 20 POSTS
As long as I leave my A/C off until my new condenser comes in my compressor should be fine, shouldn’t it? cause I just put a new compressor on it.
Apr 10, 2022 at 1:42 PM
ZHILL93
  • 20 POSTS
And how long should it take to replace the condenser?
Apr 10, 2022 at 1:54 PM
  • 110,248 POSTS
Yes, it should be fine. It shouldn't turn on even if you try because the low-pressure switch will prevent it. It would be a good idea that before adding peg oil and recharging it, you vacuum the system down and then recharge it because it was open.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
If you have confirmed it is the condenser, I attached the directions specific to this vehicle for replacing the condenser. See pics below. Let me know if you have additional questions or if I can help in any way.
Apr 10, 2022 at 2:12 PM
ZHILL93
  • 20 POSTS
And I just replaced the receiver drier about 2 weeks ago. I won’t have to replace it again, will I?
Apr 10, 2022 at 3:33 PM
ZHILL93
  • 20 POSTS
And here’s a little video I wanted to show you.
Apr 10, 2022 at 3:49 PM
  • 110,248 POSTS
The receiver should be fine. I'm not sure what I'm seeing in the video. Please explain.
Apr 11, 2022 at 10:25 AM
ZHILL93
  • 20 POSTS
In the video, especially if you watch it in slow motion, you can see water spraying out of the fan.
Apr 11, 2022 at 5:00 PM
  • 110,248 POSTS
I have no way to slow it down. Regardless, it sounds like you found the issue. Have you ordered a new condenser?
Apr 12, 2022 at 12:29 PM
ZHILL93
  • 20 POSTS
Yeah, I ordered one.
Apr 12, 2022 at 4:15 PM
  • 110,248 POSTS
Okay, let me know if there is anything I can do to help once you get it. Note there will be o-rings when disconnecting and reconnecting the lines. Make sure to lubricate them before you put it together. Additionally, note the need to add oil in the directions above.
Apr 13, 2022 at 11:05 AM
ZHILL93
  • 20 POSTS
Can I just add this to the low side charging port for the condenser?
Apr 15, 2022 at 4:07 AM
  • 110,248 POSTS
That should be fine. It will work its way throughout the system.
Let me know how things turn out for you.
Apr 15, 2022 at 12:46 PM
ZHILL93
  • 20 POSTS
It’s working good, there’s no Freon blowing on the lower radiator hose anymore.
Apr 15, 2022 at 1:06 PM
  • 110,248 POSTS
That's good news and thanks for the update. I'm glad to hear you got it working properly.
Regardless, please feel free to come back anytime in the future. You are always welcome here.
Apr 15, 2022 at 1:31 PM
