A/C high-pressure line
130,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
SERVERJON
I installed a new high-pressure line, and I’m in the vacuuming stage but when I turn on the vacuum, the gauges continue to read 0 after a few minutes and it looked like it was almost instant online.
Apr 11, 2022 at 8:46 AM
STEVE W.
  • 15,418 POSTS
Test the pump and gauges by shutting off the valves, does it read a vacuum then? How long was the system open or empty? If only long enough to change the line, I would check that it isn't leaking. Normally a pump will run maybe a minute at most before starting to show a vacuum.
Apr 11, 2022 at 9:07 AM
