Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Grand Am
Climate Control
Air Conditioner
Not Working
A/C stopped cooling
2004 PONTIAC GRAND AM
149,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
TIMRYANFERG
MEMBER
1 POST
The Freon is full, the compressor turns, the front grills are clean and the fans turn.
Feb 11, 2019 at 6:51 AM
Experienced Mechanic
Good afternoon,
Does or is the clutch engaged and turning?
Do you have a set of gauges to give me the pressures?
I attached a wiring diagram for you to view. Can you test for some voltages? Check the fuse listed for the compressor.
Image (Click to enlarge)
Feb 11, 2019 at 7:15 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
