Hi Larry,
Do you have a gauge set to see what the high and low side pressures are? Also, does the compressor clutch engage at all?
We just need to figure out if this is a power issue with the compressor or maybe a control issue that is not allowing the compressor to engage.
Here is a guide that will cover the basics of what could be wrong:
Let me know what the pressure is and if the clutch comes on and we can go from there. Thanks
Jun 14, 2019 at 7:13 AM
