A/C stops blowing cold air when driving
195,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
ARHODE2017
Hi, I recently replaced my A/C condenser and recharged my system and the A/C works good while i am cruising down the road, but I let it idle for little bit the A/C turns to heat. the engine fan appears to be working right. the engine does not overheat and the aux fan I can hear kick in from time to time. thank you
Jul 3, 2019 at 9:54 PM
Good morning,
Did you replace the dryer? That is required when any part is replaced.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
What are the pressures of the system when it is running? I need the high and low side
pressures.
Jul 3, 2019 at 10:56 PM
