A/C
96,000 MILES • 4 CYL • AUTOMATIC
BILLYBLUE6
My A/C only blows out hot air. It already has enough freon in it and it still blows hot air. The compressor seems to be fine as well. What could the problem be?
Jun 1, 2017 at 7:36 AM
JIS001
  • 3,412 POSTS
Verify that the compressor clutch engages when you turn on the A/C. If the clutch does not come on, verify that you have battery voltage. If voltage ok then replace the compressor. If no voltage check fuses and replace A/C clutch relay.
Jun 4, 2017 at 1:41 PM
