90904-45003 supercharger tube?
18,000 MILES • 4 CYL • 2WD • AUTOMATIC
JMCLEO
You described the problem I am having with a leaking supercharger tube on my 1997 Previa. I have not been able to find this part anywhere. Can you suggest where to look? toyotapartsdeal.com lists the part but I have received so many "no longer available" notifications I am not hopeful. If I knew the inside diameters tube, I would possibly be able to have it fabricated.
May 19, 2024 at 10:23 AM
STEVE W.
  • 15,389 POSTS
It's likely that it isn't available new. However you might go on www.car-part.com and see if there are any yards near you that have a Previa on the lot that has that hose. Then you would have something to use as a pattern if the used one isn't any good.
May 20, 2024 at 6:16 AM
