60,000 mile service
2016 TOYOTA HIGHLANDER
59,000 MILES • 6 CYL • 4WD • AUTOMATIC
BUDKIENINGER
Should i have this service performed? the manual says they are supposed to inspect a lot of stuff, 20 or more items.
I was thinking of just getting the oil and oil filter changed and maybe the transmission fluid changed as well.
I have had no problems with the vehicle, have replaced brakes, new tires from Costco and have changed the oil every 5,000. Synthetic. I'm guessing the dealership will charge $750.00 to a $1,000.00 for 60,000 mile service.
What do you think?
Thanks,
Bud
Feb 4, 2021 at 3:57 AM
Good evening,
I would definitely change the transmission oil. If you do not, you will encounter issues later on. In order to continue with no issues, change the fluid.
Feb 4, 2021 at 7:46 AM
