A/C not working
2011 PEUGEOT 308
96,557 MILES • 2.0L • 4 CYL • 2WD • MANUAL
CURVER
Our 3008 was recharged 12 months ago. Has been regularly serviced by a reliable independent garage.
Has been out four times in the last two weeks due to UK Corona-virus lock down.
Today the A/C didn't work. Light comes on the dash, pipes are slightly cool to the touch. A/C was cold when used last time. No click when turned on and no A/C fan running. Have checked 40amp A/C fan fuse. The black cap that covers the refill (cylinder on the left front of engine bay) had snapped off leaving a small, loose piece of the plastic thread. Help!
Apr 7, 2020 at 4:18 AM
  • 110,241 POSTS
It could be a few things. Chances are, however, it may have lost charge. The cap that you indicated was damaged may indicate something damaged the schrader.
Here is what I suggest: Take a look through these links. I have a feeling it is a Freon related issue. Try this first.
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Apr 7, 2020 at 10:33 AM
