0300 engine code
27,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
EDDIEGRIPPO
Today wife going to work engine light came on she said no power gas pedal did nothing.we bought the car off her mother,sitting awhile 6 months with a full tank. put 170 miles or so before this incident. would not start. had it towed home.three hours later it started no problem.scanned it 0300 came up. question is, can't find problem did notice gas was under a 1/4 tank put fresh gas in it took it for a ride 10 miles or so ran great lots of power no codes. could bad ethanol gas be the culprit? Thank,s ED
Dec 6, 2019 at 6:08 AM
  • 110,248 POSTS
Ed,
The code you have is a random misfire code. With that, old fuel could have caused the issue. Also, a weak fuel pump along with a few other things. If the vehicle is not running properly, it may be fine and just the result of old fuel.
If it starts giving you trouble, let me know and we'll start doing some preliminary checks.
Let me know what happens.
Dec 6, 2019 at 1:43 PM
