024 and 025 codes from Eatc self test?
65,000 MILES • AUTOMATIC
STRICTLYDIMES
  • 30 POSTS
Hi
Performed the eatc self test on a 2005 grand Marquis ls with the digital climate control.
Got 024 and 025 codes.
A/C works, Freon full ( put my gauges on it) compressor cycles normally, but get hot air when putting a/c on.
Did hear some clicking/snapping at one point but not anymore, still hear faint clicking at times when changing functions.
Which actuator is needing replacement?
Thank you
Nov 16, 2026 at 2:48 PM
  • 55,743 POSTS
The 024 and 025 codes from your EATC (Electronic Automatic Temperature Control) self-test indicate a problem with the temperature blend door actuator or its control circuit
Here is what the codes mean:
Code 024: Blend door actuator fault detected during the self-test.
Code 025: Intermittent blend door actuator failure recorded during operation.
I strongly suspect the temperature blend door actuator, which controls how much air passes through the heater core.
Here is the location of the Temp blend door actuator so you can swap it out. This may be a little tough to change, I would remove the glove box.
Nov 17, 2026 at 9:00 AM
