When starting the car there is a screeching sound around the belts area
145,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
RGOMEZ273
Hi there. When I go to start the car it starts, but now I am getting a screeching sound around the belts area. I hope you guys can help me with this. Thanks
Sep 7, 2018 at 5:24 AM
DANNY L
  • 5,648 POSTS
Hello,I am Danny.
Usually that is a sign either the belt(s) are a little loose or there is a slight glaze built up.The worse thing to do is spray a chemical or belt grip on it. That just gums thing up and makes thing worse. First thing I suggest is to tighten the belt(s) If does not go away try replacing. I have attached a tutorial for you to look at. Hope this helps and feel free to ask any questions.Thanks for using 2CarPros.
Danny-
https://www.2carpros.com/articles/car-squeaking-noise
Sep 7, 2018 at 7:43 AM
