camshaft positioning sensor location
1999 MERCURY MOUNTAINEER
177,000 MILES
MVAUGHAN83
Can somebody please tell me where to find the camshaft positioning sensor location on my vehicle listed above? I t is a V8 all wheel drive 5.0 liter.
Oct 19, 2017 at 10:05 AM
STEVE W.
  • 15,344 POSTS
Up front of the engine mounted in the block above the water pump and timing cover. Where the distributor used to be. Has a three wire plug and two screws holding it on.
Oct 19, 2017 at 10:32 AM
MVAUGHAN83
Thank you for the quick response. I will check there in the morning before I go to work. I found a sensor that looks like it just under where all the spark plugs meet up over where the distributor would be. However, when I un-clipped the clip it did not match up with the one that I was given from the auto parts store. I will have to check and see if maybe they gave me the wrong one.
Oct 19, 2017 at 11:17 AM
STEVE W.
  • 15,344 POSTS
There are both two and three terminal sensors. Yours could be either one depending on actual build date, but the three pin is the most common.
Oct 19, 2017 at 12:07 PM
