2004 SATURN ION
75,000 MILES
R WATKINS
2004 Saturn ion... car will start then die immediately. I have checked and rechecked all wiring and fuses with no resolution. fuel pump seems to be operating normally. diagnostic computer code shows a problem with security system. key was previously broken off in ignition but had no problem starting or running until rsdio was stolen.
May 11, 2013 at 7:50 AM
SATURNTECH9
  • 30,869 POSTS
What is the exact code numbers you have? Is the security light on solid or flashing while the key is in the run position?If so its most likely a bad ignition switch really common on those cars.
May 11, 2013 at 1:28 PM
