What causes the car to vibrate?
221,533 MILES • 1.6L • AUTOMATIC
ABDALLAH ALAA
The car runs normally, but there's a slight vibration at idle. However, the vibration increases significantly when the air conditioning is turned on. The vibration also intensifies when turning the steering wheel to neutral or left, and it increases further when the lights are switched on.
Nov 3, 2026 at 3:35 AM
  • 55,684 POSTS
It sounds like the engine is misfiring, do you have a check engine light on? Here is a video to help run the codes to see which ones are present.
https://www.youtube.com/watch?v=LBCpCWEFnTg
Can you please upload a short video of the problem so I can tell what is going on?
Nov 4, 2026 at 7:38 AM
