What is the reason you want to bypass the security system? Vehicle doesn't start, starts and shuts off ? For those there is limited testing to repair the problem, like replacing a receiver antenna or testing to see if it's a failed transponder and returning the system to operation. However if you are trying to disable the system, it cannot be done without having access to the actual coding in the ECU and security system software, and you would need to change other programming as well because there are multiple modules that need to verify the security system is operating before the vehicle will run.
Oct 19, 2026 at 8:58 AM
