Your check e light has nothing 2 do with ur air susp light, is the car sitting low after sitting, does airlight come on while driving? Air pump only should come on when starting, new passenger, or more weight added 2 car. If it(pump) comes on speraticly, u have a leak in the system, usually the air springs, if not replced, pump will burn out. Arnott inc. Is the place 2 call, 4 new pump, and 2 new air springs. Ez 2 install. 365.00 for the kit. Coil springs r an option.60.00 at pepboys or autozone stops the headache, takes away from the ride though
Monday, February 4th, 2019 AT 6:15 PM
(Merged)
