How to Retrieve Range Rover Codes OBD1 and Definitions
Step 1 - When a code is stored the "check engine" light will illuminate. Most of these trouble codes are made up of two digits and are accessible under the passenger seat.
Step 2 - Turn the ignition key to the "ON" position the trouble codes will start to display. The first set of blinking lights will be the "tenth" digit and the second set of blinks tell the "one" position.
Step 3 - Example, if the first blinking light flashes off and on twice, and the second blinking light flashes once the code number is 21.
Step 4 - To restart code gathering sequence shut the key off and then back on again.
Step 5 - To clear trouble codes after the repairs have been made turn the ignition key to the "on" position, disconnect the serial link mating plug, wait ten seconds and reconnect the plug. Switch the ignition switch to the "off" position for five seconds and turn the ignition key back on again.
Range Rover ODB1 Trouble Code Definition Table
Code 02 - Power interruption
Code 12 - Airflow meter
Code 14 - Coolant sensor
Code 17 - Throttle potentiometer
Code 18 - Throttle potentiometer input high/airflow meter low
Code 19 - Throttle potentiometer input low/airflow meter high
Code 21 - Fuel tune select
Code 23 - Fuel supply
Code 25 - Ignition misfire
Code 28 - Air leak
Code 29 - ECU memory check
Code 34 - Injector bank A
Code 36 - Injector bank B
Code 44 - Lambda (O2) sensor A - left bank
Code 45 - Lambda (O2) sensor B - right bank
Code 48 - Stepper motor
Code 40 - Misfire bank A - left bank
Code 50 - Misfire bank B - right bank
Code 58 - Group faults 23/28
Code 59 - Fuel thermistor
Code 68 - Road speed sensor
Code 69 - Gear switch
Code 88 - Purge valve leak
Questions?
If you have a car repair question, you can ask the 2CarPros community for help. We hope this guide helped you understand the repair. Please visit our 2CarPros YouTube channel for more helpful repair videos.
Repair Safety Notice: This guide is provided for general informational and educational purposes only. Vehicle repairs can involve risk of injury, property damage, or vehicle damage. Always follow proper safety procedures, use the correct tools, support the vehicle securely when raised, and consult a qualified automotive repair professional if you are unsure about any step.
