OBD2 Diagnostic Trouble Codes (P-Codes) Table + OBD1 Retrieval Methods - 2CarPros
Use this hub to look up OBD2 diagnostic trouble codes (P-codes) and jump to the matching repair discussions.
Most popular: OBD2 P-Code definitions
Go to OBD2 Trouble Code Definitions (1996+ for most vehicles).
Older vehicles: OBD1 retrieval + manufacturer tables
Go to OBD1 Codes + Retrieval Methods (manufacturer specific).
Tip
Write down the code(s), fix the underlying problem, then clear codes and re-test. If you need help, use the related forum links from the code tables.
Repair Safety Notice: This guide is provided for general informational and educational purposes only. Vehicle repairs can involve risk of injury, property damage, or vehicle damage. Always follow proper safety procedures, use the correct tools, support the vehicle securely when raised, and consult a qualified automotive repair professional if you are unsure about any step.
