HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Engine
Symptoms
Not Running
SPONSORED LINKS
1997 Toyota Corolla Car wont start
GAKSPU
MEMBER
1997 TOYOTA COROLLA
Electrical problem
1997 Toyota Corolla 4 cyl Front Wheel Drive Manual
Car wont start, check fuse and the 30A MA2 fuse is blown. Replaced fuse and still it blow out. What is the equipment that this fuse is for?
Friday, April 2nd, 2010 AT 11:30 PM
MMPRINCE4000
MECHANIC
Does fuse blow immediately?
SPONSORED LINKS
Saturday, April 3rd, 2010 AT 8:13 AM
GAKSPU
MEMBER
Yes right after turning the ignition key, just before starting.
Saturday, April 3rd, 2010 AT 9:03 PM
MMPRINCE4000
MECHANIC
You will have to trace wiring for a short to ground. The wiring insulation is most likely missing.
Sunday, April 4th, 2010 AT 7:24 AM
GAKSPU
MEMBER
Thanks very much.
Sunday, April 4th, 2010 AT 9:13 PM
MMPRINCE4000
MECHANIC
Thanks.
SPONSORED LINKS
Tuesday, April 6th, 2010 AT 10:52 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1997 Toyota Corolla My Engine Will Not Start When It...
Electrical Problem 1997 Toyota Corolla 4 Cyl 176521 Miles I Live In Louisiana And It Isjustnow Getting Cold. My Car Will Not Start In...
Asked by
Georgiaoneal
1997
TOYOTA COROLLA
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting - Top 3 Easy Steps
Over the past 20 years on 2CarPros we have identified the top three problems that are easily fixed. This can save you a trip to the repair garage or calling a tow truck and...
1997 Toyota Corolla
Electrical Problem 1997 Toyota Corolla This Problem Only Happens After The Car Has Sit Overnight. Try To Start The Car And It Will...
Asked by
bmwowner
1997
TOYOTA COROLLA
1997 Toyota Corolla Strating Up In The Winter/cold
My Car Usually Runs Great, Until Winter. When It Gets Cold My Car Takes A Little Longer Than Usual To Start Up. It Still Starts With The...
Asked by
dkhieu
1997
TOYOTA COROLLA
Cranks Good But No Spark I Have Checked All Fuses...
Cranks Good But No Spark I Have Checked All Fuses Relays And All Are Good. I Am Prducing About.3v A/c And D/c Volts And Resistance Check...
Asked by
drg962
1 ANSWER
2 IMAGES
1997
TOYOTA COROLLA
Engine Not Running?
I Am Getting Codes Po100 And Po110. My Question Is: With This 2 Codes Will It Prevent The Car From Starting Completely? After Continuous...
Asked by
silvano100862
1 ANSWER
2002
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Not Running - Advanced
Crankshaft Sensor Symptoms
Online car repair manuals
