Engine not running?
SILVANO100862
  • 2002 TOYOTA COROLLA
  • 4 CYL
  • MANUAL
  • 125,000 MILES
I am getting codes PO100 and PO110. My question is: with this 2 codes will it prevent the car from starting completely? After continuous cranking some times it starts and runs for about 3-5 secs and it dies quickly. I cant get it to start and warm up. I suspect more of an ignition issue like no SPARK. But those are not the scan codes I am getting. Any Imput would be greatly appreciated.
SAL
Friday, January 1st, 2010 AT 9:38 PM
MMPRINCE4000
  • 8,549 POSTS
P0110 is a MAF circuit.
P0110 is IAT (incoming air temp) circuit.
Combining both would cause car to not start, because PCM will set both to a default (rich) setting, which basically floods the engine.
Check electrical connections to both, you can buy a MAF cleaner to clean MAF and also use it to clean electrical connections.
If problem persists, you will need a mechanic to test both and replace if necessary.
Monday, August 10th, 2020 AT 12:57 PM
