Stereo wiring
HENRY DERUELLE
  • 2001 FORD F-150
  • 4.6L
  • V8
  • RWD
  • 300,000 MILES
Had my factory radio stolen from my truck. (Wire harness was cut.) Bought a FM mps3 deck to replace original. Question is wire diagram I found on line lists the ground wire as being black/light green. I see two wires with that color. Do I take my black ground wire from the deck and connect it to the other two?
Friday, September 21st, 2018 AT 12:46 PM (Merged)
CARADIODOC
  • 33,752 POSTS
You do not need both wires. One is for the radio section and one is for the amplifier section. Both wires go to the same ground point on the truck. Either one will work for your ground wire.
CARL TODD PEABODY
  • 2001 FORD F-150
  • 200,000 MILES
Need the correct colors to install a aftermarket radio. Need amp turn on wire and both twelve volt wires please. Help sitting in the truck, at a loss.
STEVE W.
  • 13,003 POSTS
15A Fused - Battery - light green with violet trace
5A Fused - Hot in run or accessories-black with pink trace.
5A Fused - Hot in start only - red with black trace.
Remote on. Was not in base models only up-level units with CD changer.
Light green with black trace.
Illumination wire - light blue with black trace.
