1997 Ford F-150
DUCKSLAYER
  • 1997 FORD F-150
  • 6 CYL
  • MANUAL
  • 260,000 MILES
I have a ford f150 and it stalls when I press te clutch in to stop it has done it one day last week it quite 3 times that day and it quite today 3 times the rpm drop all of the sudden and will go from 2 to zero and shut the truck will shut off all the lights on the dash do not come on and the radio stays on when it quites it will crank right up
Tuesday, August 24th, 2010 AT 2:29 PM
  • 108,268 POSTS
Has the check engine light come on? Have you checked fuel pump pressure or for vacuum leaks?
Tuesday, August 24th, 2010 AT 9:14 PM
DUCKSLAYER
  • 5 POSTS
Yes the light is on it has a new fuel pump on it it has no vacume leaks
Wednesday, August 25th, 2010 AT 11:53 AM
  • 108,268 POSTS
If the check engine light is on, there is a code stored in the computer. Have the computer scanned. Most parts stores will do it for free. Have it done and let me know what codes they find.
Wednesday, August 25th, 2010 AT 2:23 PM
DUCKSLAYER
  • 5 POSTS
I had it done they said there were three code the intake manifoldrunner control, mass air flow sencor and the o2 sencor
Wednesday, August 25th, 2010 AT 7:41 PM
  • 108,268 POSTS
Start with the runner control. It may clear the other codes.
Wednesday, August 25th, 2010 AT 9:05 PM
DUCKSLAYER
  • 5 POSTS
It is stuck open is there any way I can fix it with out having to buy another one
Thursday, August 26th, 2010 AT 1:46 PM
  • 108,268 POSTS
To the best of my knowledge, there are no serviceable parts in it.
Thursday, August 26th, 2010 AT 9:45 PM
DUCKSLAYER
  • 5 POSTS
Ok thank you
Friday, August 27th, 2010 AT 10:52 AM
  • 108,268 POSTS
Let me know what you find.
Saturday, August 28th, 2010 AT 1:00 AM
