HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Ram
Ignition
Firing Order
SPONSORED LINKS
Firing order/coil order
PREV
1
2
NEXT
CARMENJONES
MEMBER
1 POST
1997 DODGE RAM
V8
2WD
AUTOMATIC
140,000 MILES
Hi, Went to autozone who told me the #6 spark plug wire may be faulty off the test light. Do you have the location of each of the spark plug? Thanks!
Saturday, December 19th, 2020 AT 9:57 AM (Merged)
MERLIN2021
MECHANIC
This is 5.2 V8 5.9 is the same. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
SPONSORED LINKS
PREV
1
2
NEXT
Please
login
or
register
to post a reply.
Related Firing Order Content
2001 Dodge Ram Cylinders, Spark Plugs, Wiring
What Is The Firing Oder For An 01 Dodge Ram 2500 With A V8?
Asked by
jknhoops
1 ANSWER
2001
DODGE RAM
Firing Order
Whats The Diagram For The Distributor Cap And Firing Order And Cylinder Order
Asked by
slepinhimer
1 ANSWER
1997
DODGE RAM
89,000 Miles 225 Slant 6 What Is The Firing Order?
Asked by
jason2005
1 ANSWER
1987
DODGE RAM
No Spark, No Fuel
I Have The 1500 Model. I Do Not Have Spark Or Fuel. Have Checked All Fuses And Relays Multiple Times. New Crank Sensor, New Coil. New Fuel...
Asked by
Chris Gould
11 IMAGES
1998
DODGE RAM
Engine Will Turn Over But No Spark?
Electrical Problem V8 Four Wheel Drive Automatic 300000 Miles I Have A New Ecm And Have Run A Wire To Test The Fuel Pump Cutting On And...
Asked by
acbjr22
3 IMAGES
1997
DODGE RAM
VIEW MORE
SPONSORED LINKS
Spark Plug Replacement Ford Escape V6 3.0L
How to Repair an Engine Cylinder Misfire
Misfire Random Code P0300
Online car repair manuals
