Hard starting after sitting all night
TENGEL21
  • 2002 DODGE NEON
  • 154,000 MILES
When started sounds faint but when you actually get it started it is loud for a Neon. The rpm act funny when driving and the car runs loud and gets louder as you go faster along with a kind of sputtering noise. Does anyone know what I have to do to fix it or is the car just done?
Wednesday, January 2nd, 2019 AT 12:36 PM (Merged)
HMAC300
  • 48,600 POSTS
Not actually seeing this, check compression and for exhaust leaks. scan for codes or have auto parts do it for free and check fuel pressure with a gauge auto parts rent it . then you can decide from there. See link.
RENEE L
  • ADMIN
  • 1,257 POSTS
Hi TENGEL21,
If you decide you would like to conduct the scan yourself here is a link to an article that features written step by step instructions and pictures explaining how to do the scan yourself. Also, I have included a link to our YouTube channel with a how to video on code scanning.
This is applicable even if your check engine light is not on.
Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
QUINTEZ ECHOLS
  • 2004 DODGE NEON
  • 90,000 MILES
Takes too long to crank, what might cause this?
HMAC300
  • 48,600 POSTS
Scan for codes and check fuel pressure with a gauge auto parts rent it. see link.
RENEE L
  • ADMIN
  • 1,257 POSTS
Hello QUINTEZ ECHOLS,
Here is a link to some helpful information that includes an article t with written step by step instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning.
help.
Kindest regards,
Renee
Admin
MURF077
  • 2000 DODGE NEON
Electrical problem
2000 Dodge Neon 4 cyl Two Wheel Drive Automatic
When I start this car it will crank from 4-5 sec then immediately starts, I have checked for spark and the car gets no spark for this 4-5 sec delay it does not matter if its the 1st time being ran for the day or the 5th time in a row of being started the delay is constant and because of no ignition
I have checked fuel pressure apx 49 psi I have replaced the coil pack plugs wires, cam position sensor, crank position sensor.
BMRFIXIT
  • 19,053 POSTS
If have no scanner to check what the PCM data
try and switch the ASD relay
see if that help
JABO64
  • 2000 DODGE NEON
Engine Mechanical problem
2000 Dodge Neon 4 cyl Front Wheel Drive Automatic
replaced timing belt car starts then backfire when I take my feet off gas patel it cuts off and is difficult to start back.
  • 31,937 POSTS
Hi there,
I would be re checking the timing marks and any sensor that you may have disconnected, start here.
Mark (mhpautos)
Check and verify the valve timing if its still correct. Are you getting spark and fuel?
BOBSRAM
  • 1998 DODGE NEON
Engine Performance problem
1998 Dodge Neon 4 cyl Front Wheel Drive Automatic
My 98 neon is very slow to start when the key is turned over. You can put your foot on the gas but it doesn't help the situation. It will crank for a while and then I turn the key off. Turn the key on the second time and it will fire up. The car runs fine once it is started. I believe there is an issue with fuel getting to the engine whether it be a filter or a pump?
INTERNETMECHANIC
  • 700 POSTS
Yeah, I agree about the fuel issue. Use a gage and check fuel pressure, key on, engine off. If you cycle the key to or three times without cranking, it can help the fuel system pressure up. If it's been a while since you changed the filter, that isn't a bad idea. Just make sure there isn't any pressure on the system before you take any lines loose.
Wednesday, January 2nd, 2019 AT 12:37 PM (Merged)
JAMES ROY BENNETT
  • 1999 DODGE NEON
  • 4 CYL
  • FWD
  • 123,000 MILES
I have a 1999 dodge neon, 2.0 engine. It has 123,000 miles. The engine cranks real slow to start, but starts. I checked the battery voltage and it is a little over 12v with the engine off. After starting the engine it goes to 14.3 volts. The battery was put in in 2009. Does this sound like the battery is just weak, or could my timing be off due to the mileage and the timing belt not being changed yet. Just yesterday it started really rough and the check engine light came on, but finally settled out. The fault codes were P0300, P0302, P0303. One of my plugs is gapped at.040.
What do you think.
Thanks
  • 108,524 POSTS
THe codes are for cylender misfires. That wouldn't cause it. As far as the battery, one would think it is fine being that new, but it wouldn't hurt to have it load tested at a parts store. If it checks good, then I recommend having the starter draw checked. It may be bad and drawing too many amps.
Let me know what you find.
JAMES ROY BENNETT
Thanks for the advice, I will proceed.
  • 108,524 POSTS
TWO9BOGUY
  • 1998 DODGE NEON
  • 4 CYL
  • FWD
  • 150,000 MILES
I have a 1998 Dodge neon with a bad filler hose. After I put gas in the car it has trouble starting. Is this because of the filler hose or is there a bigger problem?
  • 108,524 POSTS
What is wrong with the filler hose? Are you over filling the tank? That can cause fuel to get into the evap system and cause problems for you.
