1982 Chevy S-10 carburetor
LGROSSAINT
  • 1982 CHEVROLET S-10
Engine Performance problem
1982 Chevy S-10 4 cyl Two Wheel Drive Manual
the engine is reviving up and stays there is it a carburetor problem
Friday, October 24th, 2008 AT 10:56 AM
  • 108,544 POSTS
Hi:
First, check to make sure the chole is opening. If it is, make sure the high idle cam is allowing the linkage to move the choke. If everything is ok, I can't remember for sure because it's been awahile since I worked on a carb, but I think attached to that carb is a vacuum activated pull off for the choke. Look at that too, and make sure there is nothing simple blocking the throttle itself or a broken return spring. If none of this works, I would start looking for vacuum leaks.
Let me know what you find.
Saturday, October 25th, 2008 AT 4:54 PM
