Will not stay running?
100,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
ECLECTIC ECLECTIC
  • 21 POSTS
I have the vehicle listed above 1.8 z18xe. It starts and stalls. Fuel pressure is at 30 PSI low? Minimum 55 PSI. New fuel pump. Could I do the fuel return line pinch? If I press the accelerator a bit while cranking it stays idle. The fuel pressure regulator is in the pump. Thank you.
Oct 2, 2023 at 9:24 AM
  • 110,248 POSTS
If you are able to make it idle when lightly pressing the throttle, it sounds like the throttle body bore needs cleaned or the idle air control valve needs serviced or replaced.
Understand, this vehicle isn't offered in the US, so I don't have the specifics, but based on your description, this is what I would try.
Here are two links that explain how to service both of the components I mentioned:
https://www.2carpros.com/articles/idle-air-control-valve-service
Try this and let me know the results.
joe
Oct 2, 2023 at 1:35 PM
ECLECTIC ECLECTIC
  • 21 POSTS
Yes, it was cleaned before. Could I pinch the return line? An EVAP line is broken but that shouldn't affect idle?
Oct 3, 2023 at 6:16 AM
  • 110,248 POSTS
If you have an EVAP hose that is damaged, it will likely create an engine vacuum leak. As a result, unmetered air enters the combustion chamber and certainly will cause a rough idle or stalling at idle.
If it is a vacuum hose, you can pinch it shut or plug it to see if that fixes the issue.
Oct 3, 2023 at 12:03 PM
ECLECTIC ECLECTIC
  • 21 POSTS
The fuel pressure regulator has a wire connected to it that goes to the negative if the fuel pump. Other regulators don't seem to have a wire? I'.
Oct 5, 2023 at 4:58 AM
  • 110,248 POSTS
If there is no vacuum hose and it has a wire, then there must be a pressure sensor that controls it. Have you tried checking pressure before the regulator as you previously mentioned?
Oct 5, 2023 at 10:50 AM
ECLECTIC ECLECTIC
  • 21 POSTS
The fuel pressure was around 30 psi. I took the fuel pump out, bypassed the tank and connected the two fuel lines and have a bottle of gas under to check if it still has low pressure. It has your standard fuel pressure regulator but has a wire.
Oct 6, 2023 at 7:13 AM
  • 110,248 POSTS
Then it is an electronic pressure sensor. Please understand, I am not familiar with the vehicle. However, if you disconnect the wire to the regulator, what happens to the fuel pressure? Does it increase? If so, how much? Although the vehicles are set up differently, they basically all work the same, so this should be okay to do on this vehicle.
Oct 6, 2023 at 1:30 PM
