Yellow engine light on?
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
KRCHANDLER
If you punch the gas pedal the transmission seems to downshift to low gear. Then the yellow engine light (steady) comes on. After turning the engine off, and back on again, the transmission runs normal again when in Drive (high) gear. But the steady, yellow engine light was still on.
Do you know what’s wrong?
Mar 24, 2023 at 3:27 AM
  • 110,248 POSTS
Based on the speed you are traveling; it is normal for the transmission to downshift. However, the light shouldn't be on.
As far as possible issues, since the check engine light is staying on, there will be diagnostic trouble codes stored. We need to know what they are.
Here is a link that explains how to retrieve codes:
If you don't have a scanner, take it to a parts store and let them scan for codes. Most do it free of charge.
Do this and let me know the results.
Mar 24, 2023 at 3:33 PM
