working on truck
2004 FORD F-350
175,000 MILES • 6.8L • V10 • 4WD • AUTOMATIC
JIMMY384
come to a stop and idle drops and car dies go to step on the gas to take off car hesitates not wanting to go give a little more gas then it will after the car dies check engine light comes on and overdrive button blinks
Feb 10, 2016 at 11:12 AM
JIMMY384
took truck to Autozone they said it showed speed sensor on top of the transmission I fix that truck ran better for a few weeks then started up again took to O'Reilly's they said it show the same thing being the speed sensor
Feb 10, 2016 at 11:21 AM
HMAC300
  • 48,601 POSTS
it may be a shorted wire leading to pcm/tcm have it checked for that or it cold be a bad connection as well .
Feb 10, 2016 at 10:23 PM
