wont stay running
139,000 MILES • 4.9L • V6 • 4WD • MANUAL
TIM.BAISDEN
  • 5 POSTS
My truck is hesitating when you give it the gas and it dies out like its flooding itself but it only does it like one out of three times you give it gas, but its not running good enough to drive it and I changed the throttle body gasket and it fixed most to the problems I am having with it but this one.
Jun 28, 2016 at 3:16 AM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and iac hole with choke cleaner. then check fuel pressure with a gauge if it continues.
Jun 28, 2016 at 5:59 AM
TIM.BAISDEN
  • 5 POSTS
OK I cleaned everything and the fuel pressure is 20 psi and it still hesitates when u try and give it gas
Jul 2, 2016 at 10:11 AM
HMAC300
  • 48,601 POSTS
fuel pressure should 45-60 psi engine running and 50-60 psi key on only sounds like you have a bad pump.
Jul 3, 2016 at 1:07 AM
TIM.BAISDEN
  • 5 POSTS
I just changed the fuel pump and and fuel filter u think it could be a bad one
Jul 3, 2016 at 1:51 AM
  • 55,781 POSTS
Yes sure sounds like it, do the fuel filter too, I have seen where the fuel tank switching valve goes bad in those trucks as well. Please let us know what you find
Best, Ken
Jul 6, 2016 at 1:17 PM
