Shut off while running it does not crank or start
81,000 MILES
TLY
I have replaced the alternator, and the battery. The car still will not start or turn over, no crank noise nothing. what could it be and when it was running the car just shut off? what could it be why am I losing power and why isn't there no charge? can someone help me?
Mar 24, 2021 at 2:45 AM
PACIFICISLANDER
  • 239 POSTS
Lets try testing for no cranking and will see what happens from there.
Mar 24, 2021 at 2:14 PM
STEVE W.
  • 15,421 POSTS
If the engine was running and just shut off and now it will not even turn over I would suspect a bad battery cable or power feed from the battery. If you turn on the headlights do they come on? How about anything on the dash when you turn the key? What else isn't working?
If those are turning on, what does it do when you turn the key? Any lights dimming or clicking sounds? How about if you shift to neutral and try the key?
Mar 26, 2021 at 5:15 PM
