Transmission not shifting into gear properly
89,000 MILES • 2.5L • 2WD • MANUAL
RAY ROBINSON2
Cannot get into first gear, makes horrific noise. then can for few seconds, same sound in reverse, no warning lights are on. thanks
Dec 25, 2020 at 4:32 AM
  • 110,246 POSTS
It sounds like the clutch isn't releasing from the engine. First, is it possible for you to record the sound it's making so I can hear it?
Next, this vehicle isn't offered in the US, but there should be a clutch fluid reservoir under the hood. Locate it and see if it is low or empty. On some of these vehicles, there will be a supply hose straight from the brake master cylinder, so make sure it isn't low if that is the case.
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
Let me know what you find.
Dec 25, 2020 at 9:51 AM
