Wiring problem for after market backup camera
9,000 MILES • 3.6L • 6 CYL • AUTOMATIC
MANOJ REDDY
in my car I am trying to install after market backup camera, but am not able to find which wire should i connect. i have opened my tail light bar but could not find wires for backup light. which color wires i have to pick? please help.
May 22, 2017 at 1:35 PM
CARADIODOC
  • 34,414 POSTS
This system has been seriously complicated with computer controls and digital signals. You are going to have to take some voltage readings to see if there is a circuit that can be used.
Look at the center tail lamp assembly. It should have three black wires going to it. Measure the voltages on those wires with a digital voltmeter when the back-up lamps are on. If you find twelve volts on two of those wires, you should be able to use either one of them.
May 22, 2017 at 2:14 PM
