wire problem
145,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
ZELLDOG93
  • 111 POSTS
my brake light and dash lights went out after putting in a stereo, the fuse is all good. i just need to know that wire needs to changed.
Apr 3, 2017 at 6:24 AM
CARADIODOC
  • 34,414 POSTS
The most common mistake is people use an ohm meter to find a ground wire in the original plugs for the radio. There is no ground wire there. What appears to be ground wires are the wires for the dash lights and for the running /tail lights. Those are used to tell the radio when to dim the display, and how much to dim it. When one of those is used for the new radio's ground wire, that circuit becomes shorted to ground through the radio's metal case, then the antenna cable. Those are the white and the orange wires. They should not be used with an aftermarket radio.
Apr 3, 2017 at 8:09 AM
