I have removed the bolts from the unit but the arm is attached and I do not know how to get to it.
Feb 19, 2018 at 8:18 AM
STEVE W.
✓Experienced Mechanic
You have to remove the wiper arms from the shafts, then the cowl panel grill so that you can get to the retainer that holds the drive arm to the motor. Then you can remove the motor itself.
What is the issue you are having?
Feb 20, 2018 at 3:25 PM
ELTABOR
MEMBER
I didn't want to force the cowl and I haven't done so yet because of time and weather.
Thank You
Feb 24, 2018 at 11:35 PM
STEVE W.
Plastic parts are such fun in the cold. When you get to it we'll still be here.
Feb 25, 2018 at 10:19 AM
ELTABOR
MEMBER
Hello
I got it done, but wish I had looked for the washer pump because it doesn't work, where is it?
Thank You
Ed
Mar 12, 2018 at 5:02 AM
STEVE W.
It's in the bottom of the washer fluid reservoir. Simple two wire connector. Verify that you are getting power to the connector when the wash button is pushed. The easiest way to replace it would be to get a new tank and pump, assemble those and install them. That is because the retaining ring for the pump tears the plastic housing enough that 50% of the time they don't stay in place.
