windscreen wiper and water fluid will not work
AUTOMATIC
JAYMAN94
my windshield wipers and washer fluid will not work and I hear a buzz sound coming from the dashboard. the issue lasted a couple days until today where everything was working fine again until I tried to use the washer fluid and now it will not work and the buzzing sound has returned.
Aug 12, 2015 at 4:05 PM
KHLOW2008
  • 41,812 POSTS
Did you check the fuses?
Aug 13, 2015 at 1:34 AM
JAYMAN94
Yes, I checked the fuse. everything else is working fine, although if the indicator is on while it is on it makes a buzzing sound in time with the sound of the indicator flash.
Aug 13, 2015 at 10:20 AM
KHLOW2008
  • 41,812 POSTS
Sorry, I do not have the schematic for this vehicle so I am only able to take a guess as to what the problem might be.
If the buzzing noise comes on with the turn signals, it could mean a poor ground circuit. If you are able to do electrical repairs, maybe you can try diagnosing the problem.
Aug 13, 2015 at 11:27 PM
