Will this engine fit
160,000 MILES • 3.5L • V6 • AUTOMATIC
SINTHAVONG
Will this engine fit into my car listed above? It is the SE? model.
Take a look at https://goo.gl/GsxUqa
Sep 20, 2017 at 5:39 PM
STEVE W.
  • 15,370 POSTS
If your G6 has the 3.5L V6 you indicated the 2.4L I4 will not work. You need another 3.5.
Trans-axle, wiring, computer, exhaust, cooling, dash and suspension are all different between those engines.
Plus you really want to avoid an engine from a vehicle involved in a front impact that hard unless you can inspect it before you buy it. Because of the way things fit and how they mount an impact like that can break parts that you need.
Sep 20, 2017 at 6:51 PM
