Parts swap
120,000 MILES • V6 • AWD • AUTOMATIC
ERIC HERSEY
Will parts from a 2001 Montana fit a 2004 Montana?
Jun 29, 2017 at 10:13 AM
CARADIODOC
  • 34,401 POSTS
There are two ways to figure that out. One is to look up a part on a web site like for Rock Auto. If the same part number is listed for both years, you will know the parts interchange. The problem is if the numbers are different, you do not know why. One could simply have a new bracket welded on in case it is needed on a certain application, but that is enough to warrant a new part number.
You can also visit any salvage yard and look up a part in their "Hollander Guide". That is a very large, expensive book that lists every part on a vehicle with a code number. You look that number up in the back of the book, and it will list every application that could have used that part.
Jun 29, 2017 at 11:07 AM
STEVE W.
  • 15,367 POSTS
It also depends on what parts you want to use. 2001-2004 are first generation units, but there were a few changes in those years.
Jun 29, 2017 at 1:16 PM
