I changed the coil , distributor and rotor, and it cranked! but the wire from the battery to the alternator , arc on the AC line. I turned it off and taped it up and it will not crank back up. So I changed the Cam sensor, Crank sensor, ICM, Spark plugs wires,
Need help, I'm at a lost.
Mar 25, 2016 at 10:49 PM
