Will brake light stay on if brake pads are bad
1999 INFINITI QX60 HYBRID
240,000 MILES
CJLJ
Replaced brake light switch and top brake fluid and brake lights still will not go off.
Nov 26, 2017 at 2:02 AM
CARADIODOC
  • 34,381 POSTS
The brake light switch involves the three rear brake lights. The low fluid level switch involves the red "brake" warning lamp on the dash, and since the things that turn that light on could adversely affect the proper operation of an anti-lock brake system, it can turn on the yellow "ABS" warning light too. Which of these brake lights are you referring to?
Nov 26, 2017 at 6:21 AM
