Why is my car making the bubbling sound?
2015 DODGE JOURNEY
141,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
QUINSHANAT
It runs hot and smoking while I’m driving and makes this bubbling noise. What does this mean typically?
Feb 27, 2023 at 5:34 AM
  • CERTIFIED EXPERT
  • 53,872 POSTS
Can I ask where the noise is coming from? inside outside? Can you upload a short video of the nosie so I can hear it? Typically, if your car is running hot, smoking, and making a bubbling noise, it's likely that the engine is overheating. Here are a few possible causes of an overheating engine:
Low coolant level: If the coolant level is low, the engine may not be able to cool itself properly. This can cause the engine to overheat and produce the symptoms you described. Check the coolant level and add more if it is low.
Cooling system leak: If the coolant is leaking from the engine or radiator, the system will not be able to maintain the proper operating temperature. Look for signs of coolant leaks under the hood or underneath the car.
Faulty water pump: The water pump is responsible for circulating coolant through the engine. If it is not functioning properly, coolant may not be flowing through the engine effectively, causing it to overheat.
Failed thermostat: The thermostat regulates the flow of coolant through the engine. If it fails, it may get stuck in the closed position, preventing coolant from flowing through the engine and causing it to overheat.
This guide can help as well:
https://www.2carpros.com/articles/vehicle-bubbling-noise
Please go over this guide and report back.
Feb 27, 2023 at 11:37 AM
