When driving down the road the van will start jerking
2005 CHEVROLET EXPRESS
158,111 MILES
BENFAUST
I replace the camshaft positioning sensor I also replaced crankshaft positioning sensor I also replaced manifold absolute pressure sensor I replace mass air flow sensor all 4 oxygen sensors I replace spark plug & wires I replace distributor cap I replace rotor and I replace the distributor it all help but I steel have the same problem
Jul 18, 2013 at 10:34 PM
BENFAUST
4.3 v 6 E1500
Jul 18, 2013 at 10:38 PM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure first with a gauge
Jul 19, 2013 at 6:09 AM
BENFAUST
no codes & fuel pressure maintain 62 pounds
Jul 19, 2013 at 6:57 AM
HMAC300
  • 48,601 POSTS
try cleaning the throttle plate on both sides with choke cleanerif it still does it have the injector professionally cleaned with either gm upper engine and ijector cleaner. do not use the stuff you put in tank tis won't be strong enough. they have to hook up to fuel rail and clean that way.
Jul 19, 2013 at 7:20 AM
BENFAUST
today going to work jerking worse every time I stop at a red light it dies. code finally came on p00300 multiple miss fire twice
Jul 19, 2013 at 4:07 PM
HMAC300
  • 48,601 POSTS
multiple misfires are very hard to diagnose, have a pro scan it and freeze frame it to seeif anything is out of whack electrically . A lot of times sensors won't set a code but will read wrong voltage wise so they can try changing that part. One other thing if this has s K&N type filter on it clean it out but don't oil it, clean the maf and see if that helps. It's only with those type of filters not factory ones. You could check for a vacuum leak with choke cleaner as that can cause it as well then or if you have done this tuff do a compression checkon all cylinders. if there is a 20% variance on any of them then check to see why on the offending cylinder/cylindrs. Of cours it cold be ahead/intake gasket leak as well if you are losing coolant.
Jul 19, 2013 at 4:35 PM
