climate control harness connection repair
200,000 MILES • 4.7L • V8 • 2WD • AUTOMATIC
ANTHONY DALE ISON
When the climate control panel is out of the dash everything is adjustable; temperature, fan speed, etc. When the control is set into the dash all control fictions are not adjustable. It is a harness connection issue with that grey plug circled by one of the earlier posters. What is the issue with that connection to have constant control of the panel? I do not have voltage testing equipment, besides the adjustable function is it not at the panel once it is in the dash. Someone give accurate answer please.
Aug 8, 2017 at 7:27 AM
  • 55,649 POSTS
It sounds like you have a bad connection at the plug, I would start by enhancing the terminals by using a small pick and force the middle of the terminal downward to create more tension on the connector.
Cheers, Ken
Aug 12, 2017 at 11:01 AM
